Expo question
Not so fast. When using expo (negative on Futaba and positive on JR), this is what the graph looks like. Not a perfrect curve bu you get the idea. As you can see, the elevator doesn't catch up with stick position until you reach 100% travel. Unless you are running a point curve, if you soften the middle then you can't soften the ends and vice versa.
