RCU Forums - View Single Post - HELI DIRECT LIED - HDX300 Main Gear with Strong Steel Main Shaft for Stock Blade CP
Old 09-10-2006 | 10:01 PM
HeliDirect
Default RE: HELI DIRECT LIED - HDX300 Main Gear with Strong Steel Main Shaft for Stock Blade CP
I have changed the description with instructions:
Instruction:
- Align the top hole first to the stock head pin position.
- Let the extra length of the main shaft sticking out under the main gear or use dremel to cut off the extra length.
- Since the main gear is 137T, adjust the motor position toward the main gear about 1-2mm so that the motor pinion and main gear mesh with each other well.
- When installing the auto-rotation sleeve, make sure DO NOT PUSH them into the oneway bearing. It could damage the bearing. Twist it slightly and gently force it into the bearing. It will fit in perfectly.
- If you got problem with the main shaft that cannot go through the auto rotation sleeve, use sand paper 600 to sand off the burrs on the shaft if there is any.
- Apply loctite to the set screws on the auto-rotation sleeve.
ct420,
We have a few staffs to take care of the helpdesk tickets and emails. It may be the case that your email or ticket was overlooked or not received. If you don't get the answer in 2 days please resend another ticket or contact me directly here by PM me.
I try my best to get it work out for you.
Steve
