RCU Forums - View Single Post - Stingray Construction
Old 09-11-2006 | 01:39 PM
  #369
Moe142
My Feedback: (7)
Default RE: Fuel tank issue...
On my robart struts I only have about 1/4 of an inch to move. How can I explain better? hmmm. With my stingray on the ground and when I push down on it there is NOT much spring action. It bottoms out. So when I land most likely I will bottom out How much room do you guys have? I had to cut the struts off sooooooooooo much to fit inside of the wheel wells of the jet there is barely any movement in the struts. Can there be ajusted?
