RE: Can I Have an official Mammoth ST thread?
The clicking you hear might be the gears skipping. Since you don't have whats called a slipper clutch(slips the gears on landings not to strip them) the gears skip instead. ssj2's also does this when he jumps(RARELY). You might have a 1 speed transmission(center differential). Look at the transmission and if you see 2 gears, then its a 2-speed, if you see 1 gear, then its a 1-speed. To adjust the shift point you have to find a tiny little screw on the transmission and turn it counter clockwise to have it shift sooner.
