RE: Ignition cutoff for MVVS 116 with new ignition?
Hi Pe
So to clarify I should be able to run the new ignition on a 2 cell Lipo, right? If that is ok then the smart-fly unit should work fine, since its rated to 8V.
Somehow I was under the impression that the new ignition requires a 3 cell Lipo. If not then I'm happy.
Oh, since I've got your attention. What would be a good size Lipo to use for the ignition.
Peter
