RE: Ignition cutoff for MVVS 116 with new ignition?
I currently fly my MVVS 58 with the trim setup like you described. Its just so much simpler to just hit the switch a be sure that the engine is off the sec you hit it and not only when the fuel runs out in the carb. Its also a safty aspect. But if I can't find one then I'll do the usual trim down and pull back to stop the engine.
Peter
