RE: Ignition cutoff for MVVS 116 with new ignition?
Saflyer,
PLS hold your horses until you get the engine and can check out the ignition type. I am not sure if the new 116cc engine has the "s" or the pro ignition. The latter needs 3 Lipo cells. In that case, I would suggest you use a quality manual ignition switch.
