RCU Forums - View Single Post - The Six That Wouldn't Die
Old 09-12-2006 | 08:51 AM
General Jake's Avatar
General Jake
Default The Six That Wouldn't Die
http://www.f-106deltadart.com/71fis_pilotless787.htm
58-0787 landed in a field in Montana after the pilot had ejected. The tail markings belonged to the 71st FIS out of Malmstrom AFB at the time of the landing, however the 71st FIS was later changed to the 319th FIS, Malmstrom. Retired Colonel Wolford (Major) was the Chief of Maintenance at the 71st FIS and his name was stenciled on 58-0787 as the pilot; however, Major Wolford wasn't flying the bird at the time of the incident.
Three F-106s were on a ACM (Air Combat Maneuvers) that day when 58-0787 went into a flat spin and according to procedures, Captain Gary Faust bailed out at 15K feet. One of the accompanying F-106 pilots, IP Major Jimmy Lowe, observed the ejection and also observed 58-0787 straighten out right after ejection and reportedly transmitted "Gary - you'd better get back in it!". Major Wolford got a call from the sheriff about an airplane sitting in a field with the engine running and wanted to know how to shut it off. The sheriff was advised to just let it run out of fuel. The plane was resting gear up, engine running, on a small amount of snow, with a slight downhill grade and as the snow melted under the aircraft, it would creep forward some, which had the sheriff rather excited. A depot team from Sacramento Logistics Center, McClellan AFB came in, took the wings off, put everything on a railroad flatcar (a railroad set of tracks was conveniently located about a mile from the landing site), and shipped it to McClellan AFB, CA where it was repaired. Colonel Wolford said he'd like to have flown it out of there but after the aircraft was lifted up, the under side damage was greater than thought. The Stable Table had exited the bottom through the 05 panel area and crunched its way back to the rear of the plane ruining the armament bay doors. The wings were in perfect shape. This is an accurate story from the guy who were there, and verfied by Col Wolford. Thanks to Erv Smalley for sending me this info.
58-0787 Article from the Mohawk Flyer, 10 March 1978 - submitted by Bill Chapman, 15 Oct 00
