RE: Pfalz DIII resources -- Photos, Drawings, Plans, etc.
Seth,
One way I have made plaques is to take the picture like your attachment in the above post and scan it down to the correct size. After printing it on regular paper you can use a copier to print it on overhead transparency film. Then you can cut out the plaque from the film & use double sided tape to glue it to a brass/steel shim or thin white plastic to make a finished plaque to be put in place. With a little thought on materials and care when making, they can turn out very good.
