1/2a float plane
If you are only flying in calm wind (which is probably the case with a smaller plane) then you won't really need the water rudder. Having said that, it doesn't weigh much if you do it right (pull-pull from the air rudder using fishing line works well) and it will be much easier to taxi on the water.
