GEM 2000 Mounting suggestions?
You do not put the plastic ring back on....a 1/4 inch hole is the perfect diameter for the green lens. When you push it in the hole from the rear , it will snap into place. Then just push the led in and it also will lock into place...very clean installation...I mounted mine on the right side at the rear of the frames, easy to see and check when I bring it down to check fuel level....Bill
