RE: spe 26cc problems
Set both needles two turns out, and then try again. The engine refusing to go beyond idle is a sure sign of lean settings, so make sure you start out rich.
With Aspen, be careful not to flood the engine. You need to know whether you are on the safe side, or the wrong side of flooding all the time. The combustion limits of Aspen are a little narrower than gasoline.
