RE: Lanier Extra 300s 1/4 scale kit
Great input Superworm.
I have heard about using hardwood inset into the foam core where the horn will be. However I doubt I will manage using such hard material and then sand it flush with the core without altering the original profile. I will stick with balsa inset for the spot where the horns will be mounted instead.
Ah..., I will look into that buttstrap. Perhaps capsule this joint with some epoxy?
