RCU Forums - View Single Post - prop size?
Thread: prop size?
Old 09-13-2006 | 10:33 PM
AKFireMedic's Avatar
AKFireMedic
Default RE: prop size?
#3, yes, you did feel less compression because the engine was warm which means the cylinder sleeve expanded and left the piston effectively smaller in the hole. Totally normal. When your engine is realy worn out it will have so little compression when hot that it won't stay running...then it is rebuild or new engine time.
