Spark plug kit to convert a glow engine?
Is there a kit to convert a glow engine to gas? I mean how hard could it be? You need a plug the same thread as a glow plug and a magnetic ring to go behind the prop and a pick up and a micro chip that you could program the spark advance acording the the RPM and a small coil and CDI ignition modual.
It seems like high time that there were small gasoline engines again. They could make them no problem in the '30s so you would think that it could be done alot better now. $18 a gallon for fuel is just stupid when you can buy it at the pump for $3 and add oil.
