RE: Tank Battles?
My sons and I have devised a bit of a tank battle which not only allows the direct attack on an opponent but their outposts as well. We set up 5 or six banners of thin crepe in red or yellow, depending on which side you represent. These are affixed across a u shaped metal frame and strategically placed into the ground on each players side. Each represent targets that each tank must defend or loose the battle. It takes one hit per banner, airsoft pellet must penetrate the tissue, to effectively take that target. Here the tanks are committed to more than just wailing away at each other. Of of course the possibilty exists to take out your opponet directly. Only one shot in the rear, two in one side and three on the glacis will do them in. Each battle is timed for 30min and a third player is an obsever/umpire when he is not driving. It works for us and can be a real blast.
Falke
