RE: programming flaps and aileron into one big flaperaileron
so if you have flaps which go to 90 degrees down you mix aileron and flaps as you reduce flaps? I guess I never thought of that as I was using the rule of thumb where you run the flaps at 50% of movement of ailerons. How do you do that if when flaps are engaged they both go down together, opposed to ailerons which provide roll control; one up, one down?
