RCU Forums - View Single Post - Is my Hyper .21 carb. bad??
Old 09-15-2006 | 08:50 AM
J_Bone's Avatar
J_Bone
Default RE: Is my Hyper .21 carb. bad??
I would call Nitrohouse and talk to Rob. They don’t have a complete o-ring kit listed, but they can get one made up and send it to you.
I have owned a couple Hyper 8 ports and tested different carbs. You will lose performance when using the OS 20e carb. The stock carb is a great carb if setup correctly. But what happens too is the o-rings dry out and then it makes it impossible to tune. Replace the o-rings and you will have a cheaper fix and better performance. Then tune it like Rob from Nitrohouse was quoted above.
