spinner adapter nut for moki 1.8?
I machined my own spinner nut out of aluminum. It is a lot lighter thin a steel nut and yes it is a 10 mm *1.0 .dave brown uses a 10-32 on the other end. you will also have to bore out the back plate to 12mm. and an 18 /8 will not fit the spenner you have to cut bigger slots.
