RCU Forums - View Single Post - spinner adapter nut for moki 1.8?
Old 01-30-2003 | 04:31 AM
lcgj
Default spinner adapter nut for moki 1.8?
I think it will work because thare is not that much force on the outer nut but i would not put a lot of torqe on it may be some 242 lock tight most of the load is on your inner not the outer one is just for the spinner wich just go 's around. My nut is all one peace not two. just the nut with 10 mm and 10 32 threads it goes from 12mm to .5 to .8 for thewrinch with four flats and thin it hase 45 angle to a .25 neck about .6 long. its about 1.6 long all to gather.
