RE: MW44 Oil Mixture?
To H Dale
DONT CHANGE THE PUMP!
they are matched to the ECU(i have two with strict instructions not to mix the pumps and ecu's)
The flow rate is so low on idle that any mismatch between the revs and pump voltage will cause flame out or flame up!
Graham
Check with Wren before doing anything.
