RCU Forums - View Single Post - CG Ultimate Bipe arf
Old 02-05-2002 | 02:11 AM
TailTwister
Default CG Ultimate Bipe arf
I'm on my second CG ARF. The first one went in due to a batt failure. Seven days later I flew the second one. I absolutely love this plane! It is a great ARF version of the kit. The field assembly is a bit better due to the cabane pin being replaced with bolts and a plate. I also added some strength to this area. I thought the gear was a bit thin and rigged a reinforcement made from the gear of the first plane. Otherwise glue the tail in straight and seal the hinge lines and fly. It goes together that fast. I also agree on the color. Adding some yellow stripes under the wing or something would be nice to help with orientation. It is an incredible aerobat that just happens to be stable in all flight modes.
