RE: My Brushless MT2-18SS with Mamba Max and A123 cells
Thanks for the props guys. I'll get some speeds and videos on it once the roads around here dry.
Each pack is 3 cells, 9.9v, 2300 mah. Right now I'm running them in parallel, so I've got 4600 mah, and I can adjust the voltage between 9.9 and 14. If this truck isn't exciting enough, I can still put in a higher capacity motor and controller along with a second $39 turbo module, and produce 20-28 volts. It would only have around 1500-2000 mah at those voltages, but it should be quick on the dirt...
Unfortunately, I don't have a scale small enough for an RC truck, so I can't weight it yet. Gotta get one of those!
