RE: New Hanger 9 p-51 mustang **Trainer?!?**
Not to bad, nice job. If you ever recover the tail section again you should add some balsa stick diaganoly to the vert. and hor. stabs between each rib. This really helps to settle the plane down a bit. Also good oppiritunity to replace those ca hinges with robart hinges, they work like a charm. Good luck
Shane
