ORIGINAL: langya
Okay guys I know everyone here knows how to set this up..I dont...I have no power to the motor or motor wont turn..
I'm trying to set up the ESC but seems having lots of problem..The other 35A ESC I have not a problem but this one i have. It has 5 set up beep. Not sure which is what. I know of 1 beep stick up, 2 beep stick down, 3 beep stick center, 4 beep? then 5 beep?..Everything work but the motor wont turn..Little help do appreciated..
You are correct, the new Align esc has 5 settings, (the 5th setting isn't listed on the paperwork).
Number 5 is throttle responce, low is like the original Align esc's, mid will be faster, high, will be a very fast throttle responce. The other settings are listed on the paper.
Don
