RE: Stop using CA glue for your tires
While I won't be using it since I'm now a racer and need to be able to repair the tires between runs(if necessary), it's a great tip for any bashers I imagine.
I think you should post about this stuff in the monster truck forums because I think that would be the area with most bashers.
Also you are all acting a bit childish:
Mike SVOR: he wasn't insulting/attack/etc you. It's called constructive criticism.
Other guys: he explained in one of his first posts that if CA is working for you then keep using it. It's just an alternative.
