RCU Forums - View Single Post - COX .49 power problems
Old 09-17-2006 | 07:45 AM
B.L.E.'s Avatar
B.L.E.
Default RE: COX .49 power problems
You are talking about the Cox .049 reed valve engine I assume. The fuel tank is the back plate for the crank case. An air leak between the fuel tank and crank case will have you chasing the needle valve all over the place. Try a little silicone rubber on the gasket between the tank and crank case.
