RCU Forums - View Single Post - DA-50 Ignition Module problems
Old 09-17-2006 | 08:14 AM
zzw26n's Avatar
zzw26n
My Feedback: (45)
Default DA-50 Ignition Module problems
I had the stainless covering on the plug wire wear thru on one side, were I can see the white nylon inside. Will this keep the plug from firing? And how do you test the ignition module to make sure it's still working? I can't get it to fire and I can't see a spark on the plug.
Any advice would be appreciated. My fault hear, not the engine.
zz
