RCU Forums - View Single Post - Evader ST Diff problem
Old 09-17-2006 | 01:49 PM
Evader ---> MGT's Avatar
Evader ---> MGT
Default RE: Evader ST Diff problem
Also, don't loosen your diff so that it just gets the truck moving, you don't want it to slip, so tighten it until it's as tight as it will get, then back off just little bit, like an 1/8 of a turn. Make sure your slipper slips before your diff as well. YOu don't need aluminum. I no longer use ali as well because the diff is much smoother with plastic.
