RCU Forums - View Single Post - matrix shocks
Old 09-17-2006 | 04:06 PM
totoybato
Default matrix shocks
hi,can i use thicker washer under the shock piston coz the stock washer keeps bending and goes through the shaft,is it possible that im not bleeding enough oil.if i use thicker washer the piston will be higher and may hit the diaphram.thanks
