RCU Forums - View Single Post - COX .49 power problems
Old 09-18-2006 | 11:28 AM
Remby
Default RE: COX .49 power problems
True, the needle can turn through vibration, and as he is bench running, just look at the needle as it runs to see. If it is self turning, check the prop for running true, it can cause this to happen. Also, bent prop screw if bad enough.
