RCU Forums - View Single Post - Can't decide on trainer plane, please help
Old 09-18-2006 | 01:16 PM
RC_Heli's Avatar
RC_Heli
Default RE: Can't decide on trainer plane, please help
You really think my LiPos will work with the Slow Stick, Each weigh 158g, Thats 5.55oz.
Here are the specs on the Slow Stick:
SPECS: Wingspan: 46.3"(1176mm)
Wing Area: 505.9sq in (32.64 sq dm)
Weight: 11.9-15.5 oz(338-440 grams)
Wing Loading: 3.39oz/sq ft (10.3g/sq dm)
Length: 37.6" (954mm)
Center of Gravity: 3-3/4" (95mm) back from the wing's leading edge
CG for Glider Version: 2-1/2"-3-3/4" (65-95mm) from the
wing's leading edge dependent on wind conditions
Control Throws:
Elevator: Up & Down 20°
Rudder: Right & Left 35°
Using a 30A esc and brushless motor on the Slow Stick, do you think I could use both the Lipo packs and NiMH Packs. Basically what I'm trying to ask is if I set the Slow Stick up for a brushless motor and LiPos will I still be able to fly with the NiMH packs or does that require separate ESCs
Are there any ESCs that can use both LiPos and NiMH batteries?
I guess what I'm after is a set-up that I can get the most out of the equipment that I already have.
