RE: Can u guys help me with my menace? Clutch prob
Hey seems like the clutch spring broke, if you put a new clutch in that should fix the problem, a lot of times with menaces' you have to make sure the idle is not set to high. If it is this can cause unnesscary heat in the transmission and can lead to stripped spur gears. Also the menace is known to burn up clutches because of the extreme amount of torque the truck has, depending on how much you have driven it a new clutch is just normal maintance. You might want to make sure you put the clutch on properly or this can lead to your truck not wanting to idle.
