RE: CMPro Giles 202 - 50
Well sounds good then because I wasn't expecting it to be 3d, the only 3d thing I kind of wanted to do was hovering, harriers would be fun too.Have you tried harriers at all?But other than that I like the fast and sometimes violent stuff like blenders.
Another question, did you use the carbon fiber rod with the split y rods to control both elevator halves, and if so how is it working?I had a plane go in because the stab broke off from tail flutter with that kind of setup.But that one had flimsier wires that connected to the elevator halves and I have several other planes with this design that work fine.And if you have any other tips let me know, also I am going to use HiTec 322 servos all around, think they should be enough?They are 42oz of torque.Same servos our local hobby shop owner uses in his whats it so I figured they should be enough.
Oh yeah as for the real 3d stufff I just ordered a Tribute, should be fun.
