RE: EasyStar motor question
That ESC will work fine just read the directions that come with it ,also use the capacitors, read the manual that came with the easystar it explains how to do it.When I put my E S together I din't use kicker because without it you have a little time to move things around if it's not perfect,but with kicker once you put the pieces togeather that's it.Good luck you are going to love that bird.
