RCU Forums - View Single Post - monokote and acetone help
Old 09-19-2006 | 03:27 PM
KW_Counter
Default RE: monokote and acetone help
I haven't heard of using acetone but I have heard of using window cleaner.
The window cleaner MUST have ammonia in it. That is what softens the glue.
I've also heard this only works on Monokote.
Spray the cleaner on the plane
Peal the backing of of the trim
Place the trim where and how you want it.
Squeegee out the excess cleaner.
Make sure it has no bubbles and is where you want it.
LEAVE IT ALONE Let it sit overnight for the chemical reaction.
Some like to use trim solvent on the edges - I haven't done it enough to comment on this.
There are other threads on this if you want to do some searching.
Good Luck,
KW_Counter
