RCU Forums - View Single Post - Lanier Extra 300s 1/4 scale kit
Old 09-19-2006 | 05:34 PM
  #117
Rate1's Avatar
Rate1
Default RE: Lanier Extra 300s 1/4 scale kit
You do have a point with having balsa sheets glued to become a whole skin does leave less likelyhood on things that could go wrong when vaccum compered to just have sheets taped together to make up a skin. I guess making a skin before this process is my best bet then... Thank you for the heads up. Doing so I will use the method you just described as CA glue makes is very hard to sand the made sheet true, leaving hard and almost impossible ridges to sand flat on the skin resulting in a poor finish.
Lanier RC do sell induvidual parts to this kit wich is a comfort if worst would come to happen. This is a much easier way for me to solve a catastrophic incidents since I am lacking skills and tools.
