RCU Forums - View Single Post - Hitec Eclipse 7 Elevon Mixing endpoints
Old 09-20-2006 | 12:17 AM
redgiki
Default Hitec Eclipse 7 Elevon Mixing endpoints
Howdy! I have an aircraft which uses elevons. My Eclipse 7 drives the plane pretty well, but I've run across a problem I have difficulty sorting out. When I set the throws mechanically to give me the high roll rate I want, the elevator control is too sensitive to be a comfortable flyer. When I set the throws to the elevator response I want, of course, the roll rate isn't as high as I'd like it.
What I really want is for my elevons to be able to go full deflection on a roll, and only partial deflection in response to elevator controls. Basically, 100% aileron, and about 50% elevator. However, trying to set up endpoints only adjust the servo on a particular channel, not the intended control surface itself.
How do I set an endpoint so that it modifies the control surface deflection *after* the mix has occurred? On my Futaba 6exa, it was very intuitive; setting an EPA for elevator would adjust the throws of both control surfaces in the "elevator" direction, while retaining full aileron control. I like my Eclipse, but I'm so frustrated with trying to figure this bit out that I'm almost ready to go back to my Futaba!
Thanks in advance for your help.
--Redgiki
