RCU Forums - View Single Post - DA-50 Ignition Module problems
Old 09-20-2006 | 03:33 AM
amjflyer
Default RE: DA-50 Ignition Module problems
Far more of a worry is that if you loose the shielding on the HT leads to the plugs your ignition is emitting a ton of EMF that will likely interfere with your RX and at the least reduce range considerably. So not worth the risk, composites, especially carbon, will cut through the DA shielding in 1 or 2 flights without some spiral wrap around it and clips and grommets where possible.
