RE: Safety Question
Prop Clearance May Be An Issue larger Wheels May Be Needed.A Test For The Needle Valve Is When You Have It Running Wiggle The Needle To See If You Can Produce Bubbles ( Not To much Force,You Can Make It Leak).
The Reason Being That The O-rings On The Needle Or Were It Screws Into The Housing Are Worn Or Cut.
