RCU Forums - View Single Post - 18CX engine not starting
Old 09-20-2006 | 01:58 PM
Fr33ze
Default RE: 18CX engine not starting
Oh, crankshaft, you need a pistion-stop tool that threads into the glow plug hole and will lock the crank using the piston without hurting it, and that should let you remove the clutch nut with a socket. (or use pliers or vicegrips if its stripped)
Most any other way will damage the engine is some way as far as I know...
