RE: Robart air valve question?
One valve controls the lowering and the other the raising (retracting). Screw the needle valve in to slow it down, out to speed it up. For the leak, I suggest powering it up (air) and going over each connection with a soapy water mix looking for bubbles. Another way is to use a piece of fuel tubing - one end close to your ear and the other at each connection - and listen for air escaping. This can be done with a tubing extension aimed at the connections (closely) to get to hard to get to places.
