RE: compatibility for matrix
Straight cut ring gears are actually stronger. Spiral cut ring/pinion gears work smoother but they are weaker anyway. Instead of having a solid flat conact like a normal diff the spiral cut ring/pinions catch the end of the gear then mesh in as the gear turns making it easier to chip a gear.
