RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 09-20-2006 | 10:22 PM
  #3054
13BT's Avatar
13BT
Default RE: Air Hogs Aero Ace!
soldering stuff is pretty easy sama, you just need to heat solder into both bits you want to join first. then apply heat to one or both ends till they melt into each other. as soon as that happens, take the soldering tip away and blow gently to cool the joint into place.
