Texas Hurricane firewall problems.
Bozwth,
1. I used 3 dowels on each side only.
2. The dowels are inserted 1/2 into the fire wall.
3. The carbon balsa panel part# LP-26C was $10.00.
4. Yes I used 30min epoxy. I did drill a series of 1/16 holes in the panel under the triangle stock for better adhesion.
5. So far it has held up well. It seems very strong.
6. I did use epoxy on all surfaces.
7. It is fitted between the side braces.
8. I did use cloth over the triangle stock.
I also dilled the mount holes in the carbon fire wall installed dowels and then re-drilled so that the wall does not crush when tightening the mount bolts.
If you decide to go this route you will have to get a jig saw blade also from the carbon panel supplier part# T-01 $5.75.
Hope this helps.
Lenny.
