RE: Hitec Eclipse 7 Elevon Mixing endpoints
I have a Eclipse 7 set up for elevons and it works very well, i use the dual rate fuction
so i can have high rates on elevator and low on ailerons as my plane has a very high
roll rate. i think my epa is set to about 90% for both ail and elv but i use the dual rate
to reduce the aileron throw, i think you find the setup almost the same if you use the
futaba radio.
