RE: Evolution type 2 ignition
Hi,
please could you check this ? Unscrew pick up and put it to the oposite thread on a one screw.pick up will be offset. If ignition will produce a spark regularly in idle-thrust, than it is problem with pick up. Please, don't spin your engine to very high RPM. A preigniton curve will be moved !! Please, send me your result's . I think it will be necessary to send it back to the producer and we will send you new one.
/ ~~~ \ / / <---- moved pick up.
| o o | o-/ o <--- threads on an engine.
original possition new possition for pick up.
