RE: Attaching antenna to plane
I agree, Minn's idea is good. I have been fortunate enough to be able to install a separate receiver in each plane I currently have so swapping has not been an issue. The hook and keeper allows antenna removal, but it is not as easy as the tube method. When I do start to swap receivers, the tube idea should be the perfect solution.
Steve
