ORIGINAL: bigchap
always take the prop off when setting up the radio on an electric plane,i learnt that one a while ago! !
The best approach is to install the prop when you are at the flight line before the battery is connected and remove it at the flight line after the battery is disconnected. When the battery is connected assume that the motor could start at any time!
