RE: Evolution type 2 ignition
For glofuel:
At this time we prepare a WEB pages, where we would like to describe all possible problems and where you will find the answers for your questions. Sorry for this. In our manual should be wrtitten that it is very important to protect a high voltage cable and I hope a protection plastic cable is enclosed in box with the engine.
And now I would like to write a little bit about a programming. You can setup a closed and opened possition for a choke, and then you set a type of silencer. After this you can see the LED flash shown on a schema shown by [bluemagic98] for short silencer (4th curve, short light longer dark.) for long silencer (5th curve, long light and short dark). You will never see it again until a next programming procedure will take place. So after power on you don't obtain an information about a type of silencer.
The 3 short flashes and 1 long flash (after power on) tells you, that ignition works properly and battery is good, otherwise LED will blink continously (1st curve). (A battery is checked during the blinking after power on.) This curve isn't drawn in a manual.
Please write me if it was useful for you otherwise I'll try to explain it in more detail.
